RCU Forums - View Single Post - OS140 Troubles
Old 01-12-2005 | 04:00 PM
Chris Moon's Avatar
Chris Moon
My Feedback: (8)
Default RE: OS140 Troubles
The 140RX likes to have the idle fairly lean in order to transition well. Also, do not try and run it slobbery rich, as the pump will just flood out the motor. You will not burn it up by getting it to run a little leaner, in fact it is probably the only way to get it to run at full throttle. The pump is very strong as set by the factory, but I would not mess with it.
