RCU Forums - View Single Post - High Quality Engine Bolts
Old 01-12-2005 | 06:42 PM
Daryl Martel
Default RE: High Quality Engine Bolts
I too agree that Grade 5 hardware bolts would probably do... but why take a chance if you can obtain better hardware without much effort. Personally, I prefer aircraft hardware. You know it won't fail on you. Regarding safety wiring, I did a Google search and quickly came up with these 2 links:
http://www.whizwheels.com/Tips/safetywiring.html - a very good link.
http://www.ultralightnews.com/pilots...safetywire.htm
BTW, you really don't need special pliers. A pair of duckbill or slipjoint pliers to give it the final twists will do, and needlenose pliers to pigtail it. Lockwire pliers are only usefull for long runs - I usually can do it just as neat by hand if the run isn't too long. Hope this helps.
