RE: Tmaxx wheels for my cen have arrived
Thanks for the info on the adapters I will order some when the checkout is working. I am not sure if I will use them but I suppose that it is better to have them than wish that I had them.
The stock MT2 tires are 136 mm tall and the wheel has about an half inch backspace. The Romulins have no backspace (or very little) so if you use a tire that isn't much taller you might not have very many clearance issues.
If you look at ndeepoffroad's MT2 with the swamp dawgs on it, it looks like the clearance isn't a problem and not much will have to be trimmed.
rolland
