ORIGINAL: mr70ss
Thanks Mstroh3961, On the cooling issue, I curved up the bottom of the cowl (opening it to the head) Here is a head on pic.. I really don't know if i'll need more cooling or not. Also finished the sheeting on the wing.
You should have adequate cooling with your setup! With the inverted saito you will have to pay close attention to positioning the fuel tank to the spray bar on the carb. Flooding can be a problem. IF it becomes a problem think about a Cline or Ironbay fuel regulator. I use them on all my inverted Saitos.....It stops all flooding of the carb.
