RCU Forums - View Single Post - AFPD IS GETTING DELIVERED TOMMOROW
Old 01-13-2005 | 09:58 AM
theKAT
Default RE: AFPD IS GETTING DELIVERED TOMMOROW
1) Make sure your transmitter isn't set for PCM. I read that in the docs and then proptly used a model memory that was set to PCM. You'll know if you do because you can't calibrate the controller. The inputs all just jump around at random.
2) Set aside a lot of time to play with your new toy...
