RE: Baffling your gas engine
That's when you need baffling most. Just because the cylinders are behind the opening doesn't mean any air goes through the fins... as soon as air enters the cowl it's going to take the path of least reistance... a beeline directly for the outlet skiping the cylinders all together. You need something to force that air through the fins.
