RE: Kitless
Make and buy some tools is you have not already, find some aluminum "T" extrusion saw it up and make your self some sanding bars. Go look on Enco's web page, you can get some 1-2-3 blocks, mini angles plates, long scales a set of dial calipers very inexpensively Note: Enco stuff is not really good enough for use in a real machine shop but it is plenty good enough to make airplanes with. Go on to Microfastners web page and buy enough hardware to make about 20 planes with for about $60. Go an old leather coat?? if you do go buy yourself some lead shot and make some weight bags. If all else fails scrape up all the epoxy CA and whatever else got dripped on your work bench and repaint it
