RE: Hinge Slots for Sig SE
For sure
I agree on the tricks for hinges and add that there whould be a check sheet you run before the first flight. This will be sure that the hinges are glued in ( easy to forget) and that the servos all have a center screw ands lots of other things. The list is the same for all planes and is easy for you to develop and add to over the years.
