RE: Megatech HouseFly Rotor Head (blade) problem
Yeap. Backwards works the best because of CG with the long boom. Forward works ok. It's not as fast at times but that's not a bad thing as I learn. I can get it to fly quite fast if I pop the throttle forward with practice. Side to side is the most sensitive. I have to be careful with the side inputs and move them very slowly. I haven't played much with the roll that much. All in all I'm having a great time flying my Housefly. Once you understand how everything works it flies pretty darn good. It's all a learning curve on making sure everything is set up right but once you get it set up right it flies great!
