RCU Forums - View Single Post - leaking at crankcase,front bearing
Old 01-14-2005 | 02:34 PM
cenracer1
Default RE: leaking at crankcase,front bearing
It doesn't take much to wreck a bearing with a bad crank... It could be off just a little bit and it will eventually destroy the bearing... If it is running fine, I wouldnt worry about it.. 4 gallons is getting into major rebuild territory anyway.
