Sig SE Metal Pushrods
Have both wings completed on my sig se, and have started planning fuselage construction. Plan to use metal rods for rudder and elevator inside the supplied plastic tubes. Have seen a thread somewhere that you could cut 1/4 inch pieces of the inner nylon rod, slip them over the 2-56 metal rods, spaced about 3 or 4 inches apart to reduce play. Have any of you had any experience with this modification? [&:][&:][&:]
