ORIGINAL: humveecrusher
Ok, thanks. I need to figure out how to get it off so I can replace the bearing. It seems a little sloppy. Mine has developed a slight pendulum circular like hover. Anyone experience this?
If you remove that bearing and take a closer look, you'll notice it has worn out, the grease from the bearing has filled a cavity and a hub has separated and no longer could hold the tiny bbs in place. When that bearing can no longer hold the inner shaft at a perfect vertical position, the shaft will wobble at its own axis causing the pendulum circular effect.
