RCU Forums - View Single Post - C-130 updates
Old 01-15-2005 | 09:33 AM
  #767
jimcork1
Default RE: 130 Flaps
You are right it will be tail heavy. My herk will sit level on the mains w/the nose wheel retracted.
You might have to add nose weight. I needed 24 oz of lead in the nose and I also put a battery back in the nose.
The radome is the location with a bulkhead and bolt for removal.
I made a LARGE CG machine to check cg, Sorry I don't remember where I put the cg, but as I remember 25% of the main cord.
Mine might have been more tail heavy due to the 3 servos and receiver in the tail.
I put the rec. battery for the tail in the landing gear box.
The rec. battery for the wing is in the radome.
Use caution and check cg closely. Jim
