RCU Forums - View Single Post - Inverted engine problem
Old 09-09-2002 | 02:41 AM
JWN's Avatar
JWN
Community Moderators
My Feedback: (42)
Default Re: Inverted engine problem
Originally posted by csandt051196
I have a 61 TT mounted inverted in a world models chipmunk. Siphon is my problem. It does not matter of the plane is right side up or upside down. If the plane is right side up the problem is much worse. I am thinking the only thing I can do is mount it sideways, I can not move the tank easily.
Scott
If you have a siphon problem both up right and inverted, then side mounting the engine will not resolve anything. You will still have a siphon problem. Personally, I don't think moving the tank will help no matter (and I cannot imagine how you can have a tank placement related siphon problem both upright and inverted anyway) what since flipping the airplane upside down will lower the tank a huge amount already.
My suggestion would be to put a hemostat on the fuel line to the carb until you can find the real reason for a up right AND inverted siphon problem.
John
