RCU Forums - View Single Post - JR8103, GY401, RaptorV2 30 setup/config
Old 01-15-2005 | 04:32 PM
WhtBronco's Avatar
WhtBronco
Default RE: JR8103, GY401, RaptorV2 30 setup/config
Yes the 649 will work with the 8103. I am using it in my Raptor 50. The 8103 can transmit FM (PPM) and PCM.
Here's the setup numbers. Please remember they will not be perfect for yours. Your heli will need some tweaking and the throttle curve and pitch curve may be a good bit different since I have a 50 and ou have the 30 size Raptor. Anyway here they are:
D/R:
POS 0 AILE 80%, ELEV 80%, RUDD 100%
POS 1 AILE 100%, ELEV 100%, RUDD 100%
No Expo used at all, per my taste.
Servo reverse:
THRO REV
AILE REV
ELEV REV
RUDD NORM
GEAR NORM
PIT REV
AUX2 NORM
AUX3 NORM
Subtrims all set to 0. I adjusted the pushrods when needed so the subtrims could be set to 0.
Travel adjust:
THRO High 103% Low 88%
AILE High 110% Low 110%
ELEV High 110% Low 110%
RUDD High 100% Low 100%
GEAR High 100% Low 100%
PIT High 122% Low 122%
AUX2 High 100% Low 100%
AUX3 High 100% Low 100%
GYRO SENS:
POS 0 100%
POS 1 10%
THROTTLE CURVE:
L 1 2 3 H
NORM 0 28.5% 68% 79.5% 100%
ST1 95% 76% 50% 80% 95%
ST2 90% 65% 43% 65% 90%
PITCH CURVE:
L 1 2 3 H
NORM 29% 45% 69.5% 86.5% 93.5%
ST1 6% 22% 48% 82% 96.5%
ST2 0% 22% 46% 75% 90%
HOLD 16.5% 38% 55% 75 100%
THRO HOLD POS 15%
REVO MIX All set to 0
No mixes set up for my Raptor yet.
If this doesn't make sense look at the manual that came with the 8103. This is directly from a page in that manual used to keep track of your settings. You'll be able to figure it out from there.
