RCU Forums - View Single Post - Taps?
Thread: Taps?
Old 01-16-2005 | 09:30 AM
Greg Covey's Avatar
Greg Covey
Default RE: Taps?
What Red has suggested is correct.
Here is what I do manually until the new FMA Cell Pro devices and chargers are released for sale.
[ul][*] After charging, measure the voltage of each cell using the taps (should be 4.2v)[*] If the voltage of each cell is within 0.01v to 0.05v of the others then you are ok[*] If not, set the charger to 1s and charge across the taps where you meaured the low voltage
[/ul]
If you use a smart charger like the Apache 2500, you are fairly safe from making a mistake as the charger will flash on any invalid setup.
In summary, the taps simply allow you to measure the individual cell voltages if you connect a voltmeter across them correctly or if you connect a charger like the Apache 2500 across them correctly when set to a 1-cell charge with a reasonable current setting like 1C.
Unless you have used your Lithium pack extensively or have created a larger pack by connecting several smaller ones together, you will not likely see an unbalance.
