RE: To maiden or Not to maiden... Tis' the question.
ICE,
Maiden it your self. You built it, you should be the first to fly it. Think about how you'll feel if some else crashes it <g>.
If the US is your 1st tail-dragger, just be aware it's a bit trickier. Hold some up elevator at the beginning of the take-off run, gradually release it as you build speed. Watch the tail wheel - when it comes off the ground, give it a little up - and there you go.
