RE: 11.1v li-ion 1800 mAh+charger for $40
The 1800 that I tested were the ones before the newer ones that they have and it would handle 12 amps with no problem. The temp got up to 118 deg F which is not bad, They say the limit is around 140 deg F Plus it held a good voltage at that rate. It took about five days to get them. I dont know if they all do but mine came with taps also.
Milton
