RE: 11.1v li-ion 1800 mAh+charger for $40
that would be fine with me..if I buy 2 of those pack..I figure flight time will be new 20 minutes each pack...the only thing that im now thinking that sux is I have 3 new cbp 1650 nimh packs..and to use the lipos..id have to set my phoenix 25amp esc to cutoff at 9volts..which means I could use my nimhs at all in the plane since they require a 5volt cutoff... unless I constanty was changing the settings on the phoenix..which might be a real pain..ecspecially since I dont have the usb connecotr...and would have to make the changes using the stick of the tx..
