RE: Mini Dragonfly help
ROOFUS4--
To answer your 11.1 li-poly volt question. Yes it is a little hig however. when you advance the throttle is starts with 0.0 volts then the voltage increases as you advance the throttle. this is how you change altitude. so lets say at 3/4 throttle you might be only up to 8.4 volts. and so on. does this kinda help. Keep in mind this is for FP blades.
