RE: Z80 problem
The set screw on the shield has nothing to do with keeping the spark plug tight. You may not be tightening the spark plug enough when you install it, it takes a very thin wall socket to remove or install the spark plug if you don't have the socket that is supplied with the engine. My ZDZ 50 has never had the spark plug loosen while flying.
