RE: PCM AV8R manual....???
Hi John:
If you will e-mail your address, I will send you the assembly instruction and operations manual.
I built one of these a couple of years ago, and powered it with a PST J600 turbine.
A good flier, but I sold it last year, as I also have some other turbines.
The only changes that I made to the kit were substituting a 1/4 in aircraft main spar and leading edge spar for the 1/8 in spars in the kit, and putting a 3 oz carbon fiber patch over the spar between the foam and sheeting.
Probably not necessary, but for the slight additional weight, I wanted to do it.
Nice looking Bonanza.
I am a pilot also
Ron Jahnig
