ORIGINAL: jmess73
Wow, I'm glad you posted that, I would have FREAKED!!! when my engine wouldn't run like a normal engine /carb setup! Ok then how the heck do I start it?????? This is going to require a very steep learning curve for me! I can get a normal carb for it right? Will it make a performance difference? I would gues that Jett also services there engines, would it be a good idea to send it in?
Jeremy
Put on the glow power, close off the muffler outlet, and hit it with a strong starter. It should fire after a second or so, when the fuel has reached the engine.
You can get a nomal carb from Jett, and it will cost you a few hundred rpm off the top end. It may be a good idea though, because no throttle on that thing will make for some "interesting" flying...
You can also get a head that accepts normal glow plugs from Jett.
