RCU Forums - View Single Post - black widow engine help
Old 01-17-2005 | 08:46 PM
Live Wire's Avatar
Live Wire
Default RE: black widow engine help
Check the back platte srews and gasket. Thats the only place fuel can run out of, other than that it has to go through the needle valve. If you take the bowl off be carefull with the reed valve they can be damaged real easy, be real carefull takeing it apart and putting it back together!
[8D]
