ORIGINAL: daveopam
On my Funtana I have 100% spoileron mixed in. That is when the ELEV is all the way up(down stick) the AILEs are all the way up. It also helps to do them inverted. It will wing rock upright. This is the same mix I use for waterfalls(end over end). Please note I have a bunch of throw and my CG is way back. You did not mention what plane you are flying. Maybe it wont 3D no mater what the setting?
A word of caution. I have my mix on the trainer switch so I can quickly disable it. When I first set it up it was on a regular switch. At the bottem of an elevator the plane is pretty hairy with a 100% spoileron mixed in. I had to go into a hover flip the switch and then fly out. With it on the trainer switch I can just let go and throttle up to fly out.
david
I have mine on switch (eclipse 7) Ive tried it on the U-can-do ,Mini 3D,Funtana 90. I know its difficult to do with a U-can-do (waterfalls) but the funtana 90 the CG was at 7 1/4 and couldnt get it to go over.. I can get planes on the sim with spoileron mix to go over, G2 and Aerofly Pro but in real world havent got one yet. I will have to keep changing the mix,, I even have a Jumping Jack electric that with do everything from Blazing blenders to perfect rolling harriers that i can transition into a torque rolling hover but cant get a waterfall[:@][:@][:@]
