RCU Forums - View Single Post - hate thrust washers helllllp!!!!
Old 01-18-2005 | 12:28 AM
Passport1
My Feedback: (8)
Default RE: hate thrust washers helllllp!!!!
the only other way is to build the thrust into the firewall which should be done when its built. If those washers are required for all the G202's then the build should simply put the firewall in with the correct off set for thrust. Without that being done your only choice is to shim the motor like they suggest, and yes it will need to be drilled off center.
Chip
