RCU Forums - View Single Post - Flaperons or spoilerons
Old 01-18-2005 | 07:02 AM
MikeEast's Avatar
MikeEast
Default RE: Flaperons or spoilerons
Well sometimes it just takes it a few of those tight loops before it really gets going. Im not sure why sometimes I can enter it perfectly and sometimes the plane will lumber around up there and then all of the sudden it bites and the waterfall fun begins. Bottom line is spoilerons will help clean up some maneuvers Also try a flaperon mix, its just the opposite, up elevator down ailerons. Its not just for landing you can do some crazy things with flaperons on, plus the plane will continue to fly since flaperons actually add lift so although you have to be careful, its not nearly as bad as spoilerons.
Mike
