RCU Forums - View Single Post - Hey Tom ?
Thread: Hey Tom ?
Old 01-18-2005 | 09:15 AM
rctom's Avatar
rctom
Default RE: Hey Tom ?
We have one white/red G202 in stock. I'm getting a few more with the EX 260 shipment, late Feb.
BTW I'm working on creating a new sport/aereobatic plane derived from the Giles called the G-Sport!
This will be a G202 fuse with different wings and elevators. The wings will have the new airfoil that we've been using and will be almost like an Edge, with a 1 degree sweep on the leading edge, forward sweep on the trailing edge, and larger ailerons. They will also be a little shorter (90" span vs. 93") and more chord, which will give the same wing area but a faster roll rate. Elevators will be larger and held tighter to the fuse for better low speed authority.
It won't be a scale model of any real plane, but should be quite good looking and be a dynamite 3d plane for the 75cc size engines, still strong enough for a 100.
The wings are on the way for testing, if all goes well it will be in production in a month or so. Expect shipments early May.
TF
TF
