RCU Forums - View Single Post - Tiger II Tail Dragger Conversion
Old 01-18-2005 | 10:06 AM
RCJake-rcu
My Feedback: (7)
Default RE: Tiger II Tail Dragger Conversion
I converted one using the white landing gear (Du Bro, I think) mounted to the hardwood/ply plate that is just in front of the wing cutout area using 6/32 socket thead bolts & blindnuts. For the tailwheel I used the Sullivan, which has four mounting holes. I used a socket head bolt (4-40 I think) in the rear hole ( factory installed blind nut there), then drilled three other holes in the bottom of the fuse and used pan head screws to tap the holes. The screws were removed, a drop of ca inserted in each hole to harden the threads, then insert the screws again. Then, just install the spring that is used to drive the rudder and, viola! Done!
By the way, the Tiger II is a great choice to use when learning to fly a taildragger. Good Luck!
