RCU Forums - View Single Post - Flaperons or spoilerons
Old 01-18-2005 | 10:49 AM
daveopam's Avatar
daveopam
My Feedback: (9)
Default RE: Flaperons or spoilerons
How I get the Funtana .40 into a water fall............... I slow the plane to nearly a stall into the wind and upright. Just as the plane is starting to get mushy and go into a stall I pull the mix on, give full down(55degrees of elev)and give full power. As the plane comes back around to level I cut the power to 50%. As it gets inverten I go back to full power. I have to keep working the throttle. I have not been able to hold full power and keep it in as BigNed described. I will have to work on that. Also the longer it goes the better they get. Mine also looses ALT fairly quick. At the bottem I just go into a hover and climb out.
david
