RCU Forums - View Single Post - Good 3D plane for ST2300?
Old 01-18-2005 | 11:10 AM
TOYMAKER
Default RE: Good 3D plane for ST2300?
Some of you where wondering about this combo. I test flew the Funtana with the ST2300 and Perry/pump/carb combo yesterday and all I got to say is....hooooo haaaa! sweet combo.
I was rather surprised that I had to add weight the nose even with pull pull rudder. The initial test flight was a hand full as it was way tail heavy. I guess I didnt take in to consideration the 20oz fuel tank behind the wing tube. I added about 3 oz to the nose and used a 16 oz tank. All the fuel in a 16 oz tank that I need as you dont need much more then 1/3 to half throttle for most flying I could fly for over 12 min on about 10 oz. a fuel mizer. But go vertical WOT with the aileron rolled over hard and it will bore holes in the sky till you cant see it no more. I will move the throttle servo to the engine box and a std spinner backplate instead of the lightened one. The only thing I did to the tail to add weight was used one diamond wire bracing and added a few grams to the rudder strengthening it. The rudder needs to be bigger or I neeed a better servo. Otherwise it was a FUN airplane to fly.
ST2300 w/Perry pump/carb combo (if you use the std carb put the fuel tank behind the firewall)
SlimLine pitts style muffler (sounded great)
15% Cool Power
OS "F" plug
18X6 wood Zinger was the right prop
For those that will run the ST with the stock carb. Put the fuel tank behind the firewall and use the fuel tank setup method descibe on Bob Pastorello's webpage www.rcaerobats.net click on Excelleron, you'll see it in the narrative. Other usefull ST2300 info is on his home webpage.
Wayne G.
ID:	216999   Click image for larger version
ID:	217000   Click image for larger version
