Yup!---Flew mine that way all summer---No problem--
ORIGINAL: wind junkie
I suggest if you do use the supplied horns, that you put the ball link on the servo end as you say, and make sure you use a sturdy servo arm (metal or reinforced pastic). Use just a clevis to the stock horn. That way, the horn will be stronger, and not twist due to an offset ball link.
