RCU Forums - View Single Post - Need Help Mixing throttle to elevator in 9C
Old 01-18-2005 | 05:12 PM
Bax
Default RE: Need Help Mixing throttle to elevator in 9C
If you're using the V-tail mixer, you can't use other mixers on the elevator and rudder channels. You'll have to turn off the V-tail mixer and use 3 Pmix's this way (M=Master, S=Slave):
Elev(M)-->Rud(S), Link ON, Trim ON
Rud(M)--->Elev(S) Link ON, Trim ON
Elev(M)-->Throt(S) Link ON, Trim OFF
Adjust the percentages to get the amount of movement on the different channels that you want.
