RCU Forums - View Single Post - Crankcase plumbing thought, Will it work?
Old 01-18-2005 | 06:30 PM
jw637362's Avatar
jw637362
Default RE: Crankcase plumbing thought, Will it work?
Thanks, everyone for the inputs, I will try them all - does not hurt. You know as well as I do that the oil cleanup is a big pain. It seems at times, that their is more oil from the crankcase mess than from the exhaust. Yet another reason I REALLY like bigger GAS engines now.
@William Robison - Long time running the engine.
Would running the crankase vent back into the intake act as if running a higher oil / less nitro content fuel. thus needing to richen the fuel flow so as not to starve the engine for fuel?? I may be way off with that question.
Jeff
