i told you all would'nt believe me ! but if you think about this plane has a symetrical tail. if you load the tail you unload the wing in turn eliminating the tip stall. and yes the plane will fly with the cg back even further. i fly 3d and found the way i set my cg is start out with manafactures recomended setting and move it back until that bad boy porpus on landing and then remove just a little tail wieght . yea hah that will make hovering a breeze! harries less harry and so on and so forth. Damn now you made made give up a secret.
Chad
