ORIGINAL: tschuy
ORIGINAL: Topgun2mo
Is the reason you are unhappy because they don't line up with your print? If that is the reason, after you have had a few landings the wire will tend to set back more and get closer to center. If you don't start out forward of center then they could move too far back and interfere with the operation of the retracts.
No I just got these struts today from Robart. The right strut was not bent properly and it looks like they tried to recover from it. The folowing pictures will better show. The right strut is obviously bent but the left set is straight as an arrow:
Cheers,
Here's some better pictures and the reason I've complained to Robart:
