RCU Forums - View Single Post - Bouncing servos
Old 01-18-2005 | 07:54 PM
wisdom-seeker
Default RE: Bouncing servos
ORIGINAL: crownvic
why do my servos bounce when they return to center if the stick is flipped
Lonnie
The stick is flipped??!! Is this as in: drag the stick to an extreme and let go? If so, what makes you think that the springs on the stick will stop the stick in the middle with no overshoot? Instead, the stick will overshoot the center and then come back, and maybe overshoot a smaller amount in the opposite direction. If that doesn't define bounce, then what does? You're actually telling the servo to bounce.
