RCU Forums - View Single Post - Hnager 9 Edge 540 Performance
Old 09-14-2002 | 11:28 PM
  #69
skerlock
Default trying to put this to rest
Ok....My Edge(H9540)has gone through 3 owners I am the third.When I got it it Snapped like crazy..I mean Really Snapped enough that on my 8th flight is snapped in to the ground and broke the fuse in two different parts that was the second time this plane has broke into two pieces. and The other two guys Told me every thing is fine... ...So as far as I'm concerned this plane should be as bad as any of the ones you all are complaining about...BUT WAIT The story's not over..I repaired the Fuse All covering off. Moved two servos to the rear for the elevators. ..Incidence IS 0 wing, 0 stab, and 0 Engine thrust line. Moved rudder servo to the back of the open area under
the wing. moved battery under the foreword wing mount..moved 22oz. tank as far back as the compartment allows... OH and lets not forget the Lateral balancing I put it dead Nuts and its the original wing...NOW the final results. It stalls as flat as it can be... I cut throttle slowed to idle flying speed w/Full 3D elevator.it sunk flat and straight down.Harrier perfect and the Wall No Snap what so ever...BY THE WAY the wing has a 1degree twist from tip to tip and the leading edge are far from perfect..MY POINT IS IT TAKES TIME TO DIAL IN A PLANE. I know we shouldn't have to do this but you got the plane so make it work I believe..I WOULD BET THAT IF ALL OF US WENT BACK AND CHECKED WHAT we Say Ive Done that its not right..I have talked to too many people in person and on line and Most say Ive Done That..or Na it is fine that way...You know what if all the steps were fine then the plane would fly Like a Dream........So Please Humble ourselves and double check everything... I am running an OS 160 w/ 18/8 mejzlik prop Have fun.. and you should see the look on the face of both previous owners.
Scott
