RCU Forums - View Single Post - Vectorflight Edge 540 build
Old 01-18-2005 | 10:08 PM
  #312
rcjon
Default RE: Vectorflight Edge 540 build
Here is my cheapo test stand. I don't use a servo and Rx, only because I didn't think of it. For the throttle control, I drilled a mis-aligned hole in the backplate and glued a piece of fuel tubing in it. I run a piece of control rod through the hole and it holds the setting. I use C clamps to attach this contraption to a table.
