RE: Edge 540 Problem
Just out of curiosity...What did you do with that plane because I purchased one from a guy...not you....and it does the exact same thing. Oh by the way mine goes right! My problem, after some pretty scary events, is a significant misalignment of the trailing edge of each wing half causing the right wing to stall alot sooner than the left wing. It acts just like hard right aileron, at any speed, coming out of a dive, loop, fly straight and pull up hard and the right wing stalls and she banks hard right. I changed servos, channels, frequencies, batteries, and more. Very dangerous on landing. Unfortunately the seller told me it flew perfectly. Maybe he bought it from you and sold it to me. Now I have a new wing and am in the process of putting it together straight. If you still have yours take a good look. My leading edges line up straight but if you tape a Steele rod to the trailing edge of each wing half, the tips of the rods should be in the same plane. My right wing half trailing edge is about 3/4" lower than the left half...right wing stalls first EVERY-TIME! Good luck!
