RE: Problem with CG Location
Listen to a65l, there is no way that you would need to put weight on the nose of that plane. Put the batteries and reciever up front and you should be fine. Plus 5-6oz is way way too much for a plane that size!
Try with the battery beneath the fuel tank first (remember, up is down when your plane is upside down!)
