RCU Forums - View Single Post - Problem with CG Location
Old 01-19-2005 | 06:32 AM
DBCherry
Default RE: Problem with CG Location
Do not fly the plane in a tail heavy condition. Forget the advice not to worry about it, while others' may not have come out tail heavy, it seems your's has.
If you used a lighter engine than someone else, then your's may well be tail heavy and may not survive the first flight unless you balance it. Move the battery pack & receiver forward, you may even be able to move the engine forward on the mount.
Dennis-
