RE: Quick Filler Position Question
Fuel draw would be fine, but while filling or draining, you'll have a lot of fuel on the ground due to the low position of the filler.
I personally had limited success with fill valves. If they don't leak now, they will later.
I use 3 line tanks with the 3rd line to a clunk and a piece of tubing that's capped off.
You can hide this fill/drain line somewhere out of sight when not in use, and it won't leak.
