RE: Stabilizing thin wing sheeting - SSE
By the time you do a good fiberglass finish and/or add foam between the ribs you could've simply removed the sheeting from the bottom of the wing, reinforced the upper sheeting and fitted a new re-enforced sheeting back to the bottom. At least then you'd have a surface to finish with no issues of smoothness or whether or not the covering would stick.
