RE: Vectorflight Edge 540 build
Welcome Sturtz, nice to have you here! I think you will be a happy camper like most VF owners. The only down side is the wait!
Rcfury, in full scale aviation sometimes thin CA is used to vibration proof a fastner. On metals it will just fill up and tighten the threads but still allow you to remove it although it will be very tight. But please do not do this on your new Saito before you can test it out on somthing else! or what about using a good spring washer, there are ones with radial indentations or grip textures on them to keep the nut or screw head from rotating. Hope your plane was fine after that runaway incident.
