RCU Forums - View Single Post - C-130 updates
Old 01-20-2005 | 12:07 AM
  #821
gunny11's Avatar
gunny11
Default RE: 130 Flaps
Progress report.
Pic. 1 - Rudder post with tork rod.
Pic. 2 - Gluing rudder post in and aligning with laser.
Pic. 3 - Once aligned, full set of clamps and a pair of wood strips on the outside to evenly clamp it inside the fin.
Pic. 4 - Looks good, but you should always at least double check your work with a ruler or tape measure. I checked stab tip to fin tip (compare to other side and should be right on) both diagonally and horizontally.
Gunny
ID:	217887   Click image for larger version
ID:	217888   Click image for larger version
ID:	217889   Click image for larger version
