RCU Forums - View Single Post - about to order 2nd plane
Old 01-20-2005 | 09:19 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: about to order 2nd plane
Personally, I prefer the wheels on the wing. True, if you break it, the fix is a little more difficult, but then, you're not supposed to break it are you?
Plus, if you DO break it, remove some bottom covering, fix it, re-cover, and it looks good as new.
As far as comparison, the T2 is more stable than the Stik, but the stik is more aerobatic. And I would put the 4* somewhere between the two.
