RCU Forums - View Single Post - Vectorflight Edge 540 build
Old 01-20-2005 | 11:27 AM
  #349
bubbagates's Avatar
bubbagates
My Feedback: (32)
Default RE: Vectorflight Edge 540 build
ORIGINAL: ez2bgman
Bill,
Most of us can relate to the wing/fuselage gap. If you have read the thread, than you also know that I have come up with a simple, yet effective method to close the gap. You can find it here: http://www.rcuniverse.com/forum/m_24..._4/key_/tm.htm It is post #118. Check it out and you may be able to use this or a similar method to eliminate the gap. I have flown three times with the mod with absolutely no problems.
Good luck and happy flying.
ez2,
I was only slightly aware of this thread until you pointed it out. I may still try that and when the new design comes in I will try that one also.
