RE: Vectorflight Edge 540 build
Ez,
I have the same Funtana 90 and that is a good setup. I even went so far as to put spring loaded cotter pins on the dowel rods on mine to give it more security should a wing bolt snap and I never thought of using the bolts for the Edge.
If you have not already, you may want to pass your bolt fix along to them. Chuck is the person I have been dealing with and he has been excellent even when I screwed up and glued the center joiner in upside down. Easy fix though. Just cut the exposed end off and redrill the holes
I agree about Vector being a well kept secret. I have nothing but prasie for them and we all know about the product quality.
