RE: question on air system
I see that you want to depressurize that one line, but will it work to just purge all of the air lines? The gear should stay locked down and you can still pull the door open? The pressure will be released when you pull the wing off any way. Robart makes the fill valve that has the valve stem type insert, you can purge the line there. Just a thought.
